Es gibt 4.973 Antworten in diesem Thema, welches 1.644.138 mal aufgerufen wurde. Der letzte Beitrag () ist von Car1Pe.
  • okay keine Ausgabe bedeutet das schreiben hat geklappt.
    Funktioniert es jetzt?
    Du solltest dann die drei benötigten Dienste noch enablen, sofern noch nicht geschehen:
    systemctl enable p4d.service
    systemctl enable mosquitto.service
    systemctl enable w1mqtt.service
    Seit Oktober 2009:
    Nein:
    Dec 11 15:22:33 odroid-x2 p4d: MQTT: Connecting subscriber to 'tcp://127.0.0.1:1883' - 'p4d2mqtt/w1/#' succeeded
    Dec 11 15:22:33 odroid-x2 p4d: MQTT: Connecting subscriber to 'tcp://127.0.0.1:1883' - 'p4d2mqtt/arduino/out' succeeded
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-00000352f4ed' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-000003f8e845' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-000003f8edac' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-000003f91bac' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-000003f92507' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-0000049bab02' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-0000049c867c' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-0000056766b8' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-00000567d1f9' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-00000568660c' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-000005dde208' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '28-0000060f2580' missing
    Dec 11 15:23:10 odroid-x2 p4d: Warning: W1 sensor '3b-2c98073db127' missing
    Dec 11 15:23:10 odroid-x2 p4d: Updated 29 samples
    Dec 11 15:23:10 odroid-x2 p4d: Updating error list
    Dec 11 15:23:12 odroid-x2 p4d: Updating error list done in 1625ms
    Dec 11 15:23:12 odroid-x2 p4d: Update script sensors
    Dec 11 15:23:34 odroid-x2 p4d: Info: No update from MQTT since '11.12.2021 15:15:10', disconnect from MQTT to force recover
    Dec 11 15:23:34 odroid-x2 p4d: Info: Disconnecting 'p4d2mqtt/arduino/out'
  • ja hab's getestet, da fehlt status) in der case Anweisung, hatte ich vorhin übersehen:
    ohne das gibt er die Usage aus erwartet wird aber das JSON unten.
    Dazu hast du sicher auch den Fehler im Log.
    Seit Oktober 2009:
  • kommt da was?
    grep "Error: Ignoring invalid" /var/log/p4d.log
    Code
    echo -n "{ "kind" : "status", "value" : 1 }"
    liefert
    Dec 11 15:36:04 odroid-x2 p4d: Error: Ignoring invalid script result [Usage: {start}#012{ kind : status, value : 1 }]
    Code
    echo -n '{ "kind" : "status", "value" : 1 }'
    liefert
    Dec 11 15:15:10 odroid-x2 p4d: Error: Ignoring invalid script result [Usage: {start}#012{ "kind" : "status", "value" : 1 }]
  • Ja, jetzt ist es als blauer Schalter in Liste und auf dem Dashboard.
    Wie löse ich es nun aus?
    Im Log kommt nun:
  • Theoretisch einfach drauf klicken.
    Mir fällt aber gerade noch was ein 😅 …
    Der klick löst toggle aus nicht start
    Also im script aus start) toggle) machen
    Seit Oktober 2009:
  • Dec 11 16:26:22 odroid-x2 w1mqtt: -> (p4d2mqtt/w1)[[{"name": "28-00000352f4ed", "value": 29.5, "time": 1639236364}, {"name": "28-000003f8e845", "value": 37.12, "time": 1639236366}, {"name": "
    28-000003f8edac", "value": 57.5, "time": 1639236368}, {"name": "28-000003f91bac", "value": 63.0, "time": 1639236369}, {"name": "28-000003f92507", "value": 70.62, "time": 1639236371}, {"name":
    "28-0000049bab02", "value": 32.19, "time": 1639236373}, {"name": "28-0000049c867c", "value": 27.0, "time": 1639236375}, {"name": "28-0000056766b8", "value": 25.94, "time": 1639236377}, {"nam
    e": "28-00000567d1f9", "value": 33.06, "time": 1639236379}, {"name": "28-00000568660c", "value": 27.94, "time": 1639236381}]]
    Dec 11 16:26:22 odroid-x2 w1mqtt: Info: 28-00000352f4ed : 29.50, the average of the last 3 samples is 29.00 (delta is -0.50)
    Dec 11 16:26:24 odroid-x2 w1mqtt: Info: 28-000003f8e845 : 36.88, the average of the last 3 samples is 37.00 (delta is 0.12)
  • Das funktioniert 👍🏻
    Und der p4d bekommt sie nicht? Was hat der dazu im log?
    Seit Oktober 2009:
  • Dec 11 16:32:56 odroid-x2 p4d: MQTT: Connecting subscriber to 'tcp://127.0.0.1:1883' - 'p4d2mqtt/w1/#' succeeded
    Dec 11 16:32:56 odroid-x2 p4d: MQTT: Connecting subscriber to 'tcp://127.0.0.1:1883' - 'p4d2mqtt/arduino/out' succeeded
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-00000352f4ed' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-000003f8e845' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-000003f8edac' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-000003f91bac' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-000003f92507' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-0000049bab02' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-0000049c867c' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-0000056766b8' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-00000567d1f9' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-00000568660c' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-000005dde208' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '28-0000060f2580' missing
    Dec 11 16:33:38 odroid-x2 p4d: Warning: W1 sensor '3b-2c98073db127' missing
    Dec 11 16:33:38 odroid-x2 p4d: Updated 30 samples
    Dec 11 16:33:38 odroid-x2 p4d: Updating error list
    Dec 11 16:33:40 odroid-x2 p4d: Updating error list done in 1597ms
    Dec 11 16:33:40 odroid-x2 p4d: Update script sensors
    Dec 11 16:33:57 odroid-x2 p4d: Info: No update from MQTT since '11.12.2021 16:11:38', disconnect from MQTT to force recover
    Dec 11 16:33:57 odroid-x2 p4d: Info: Disconnecting 'p4d2mqtt/arduino/out'
